20 Most Recent Fossil AM3726 Wrist Watch Questions & Answers
14answers
How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
4/20/2015 10:02:48 PM • Fossil AM3726... • Answered on Apr 20, 2015
2answers
Pin fell out of my fossil watch stainless band.
New pins can be purchased from amazon. Here: Amazon com fossil watch pins. I hope this was helpful. Cheers
12/10/2014 8:43:29 PM • Fossil AM3726... • Answered on Dec 10, 2014
0answers
0answers
0answers
0answers
I have a fossil Cronagraph
I would take the item to your local watch repair shop, they have the proper tools to do a quick fast job while you wait and make sure it is a proper fit.
12/31/2010 5:37:38 PM • Fossil AM3726... • Answered on Dec 31, 2010
I just purchased a great
I have looked at their web site and although it is one of the most helpful sites about, it is hard to locate instructions for individual watches.
If you can't get any help from your supplier, then follow this link to reach their customer care department. They should be able to tell you how to do it. https://www.fossil.com/en_US/shop/customer_care/contactus/fossil-contactus.html
10/27/2010 6:12:45 PM • Fossil AM3726... • Answered on Oct 27, 2010
How to remove links from a metal fossil watch band
mcdevito75 here, To reove the links you"ll need a special tool called a link remover available on ebay, or you can look for a small watch repair shop in your area for about the same cost of the tool and save on delivery time as shop can do the job right away.
8/7/2010 6:40:01 PM • Fossil AM3726... • Answered on Aug 07, 2010
How do i remove links
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
7/31/2010 7:23:39 PM • Fossil AM3726... • Answered on Jul 31, 2010
How to take out fossil watch links without
mcdevito75 here, You"d need a special tool called a link remover tool available on ebay but, the cost and time for delivery are the same as you looking for a small watch repair shop in your area to remove these links for you, hold onto the se removed links just in case you ever want to re-install them.
7/4/2010 3:20:38 AM • Fossil AM3726... • Answered on Jul 04, 2010
I am trying to remove a link from my fossil watch....
hello. Your best bet is to take the watch into a jewelry store.
They have a special tool designed to remove the link pins with out damaging anything. They may charge a few dollars but it would be worth it. J.
5/25/2010 9:32:34 AM • Fossil AM3726... • Answered on May 25, 2010
Fossil AM3726 Wrist Watch Logo
36 questions posted
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
View Most Popular
AM Fossil
  • AM Fossil
Most Popular Question
pin fell out fossil watch stainless
  • Watches
