20 Most Recent
Texas Instruments TI-84 Plus Calculator Questions & Answers
How many ml is 5 mg?
Milliliter is a unit of volume, milligram is a unit of mass (or weight). There is no direct conversion between them.
5 mg of water occupies 5 ml. 5 mg of gold occupies about about a quarter of a ml.
11/7/2023 4:15:47 PM •
Texas...
Answered
on Nov 07, 2023
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
4/11/2023 7:34:15 AM •
Texas...
Answered
on Apr 11, 2023
How do you put in
For curly braces {} use 2ND ( and 2ND ). For square brackets [] use 2ND multiply and 2ND plus.
10/15/2022 6:01:22 PM •
Texas...
Answered
on Oct 15, 2022
What is wrong with my calculator? invNorm Error:Domain
DOMAIN ERROR:
- You specified an argument to a function or
instruction outside the valid range. This error is
not returned during graphing. The TI-84 Plus
allows for undefined values on a graph.
- You attempted a logarithmic or power
regression with a LX or an exponential or power
regression with a LY.
- You attempted to compute GPrn( or GInt( with
pmt2 < pmt1.
10/2/2022 3:17:57 PM •
Texas...
Answered
on Oct 02, 2022
How do i reset my window settings for graphing
If by reset you mean revert to the default settings, press [Zoom][6:ZStandard]
If on the other hand, you want to play with the window dimensions press [WINDOW] and change the values of Xmin, Xmax,Ymin,Ymax. Make sure that Xmin Less than Xmax, Ymin less than Ymax. If domain is positive set Xmin=0., If range is positive set Ymin =0.
Hope it helps.
8/3/2022 8:33:57 PM •
Texas...
Answered
on Aug 03, 2022
TI-84 Plus calculator without ~ | or y keys
type 15 then click a button that looks like this^. then 365. Then hit enter. it is like a normal clcutor except with more function. Sometimes you need to use the 2nd and the alpha button to do some functions.
8/3/2022 7:02:36 AM •
Texas...
Answered
on Aug 03, 2022
Ti-84 BINOMIAL PDF
I encountered this same problem with the TI-84. Turns out you have to put your P (Percentage) as out of one hundred. For example. With my problem I had;
Trails: 13
P: 53/100
X Value: L1 (List 1)
And then it posted my probabilities to the L2 list. For some reason if you just put 53, or whatever your percentage of success in, it won't calculate.
8/3/2022 6:59:32 AM •
Texas...
Answered
on Aug 03, 2022
How do I convert decimal to fractions, and
If You Want to Convert Decimal to Fraction for your maths class. These types of calculations are we can learn on 5th to 10th Standards. If you are studying in 5th to 10th class and you don't know how to convert your decimal number to fraction number. You want to learn about decimals and fractions.
https://www-calculator.com/
5/11/2020 9:20:56 AM •
Texas...
Answered
on May 11, 2020
My new calculator is giving incorrect answers to
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
3/19/2020 8:34:57 AM •
Texas...
Answered
on Mar 19, 2020
My TI-84 Plus won't let me graph trigonometric functions.
Is it somehow preventing you from graphing, or are you simply not getting the graph you expect?Most likely you have the angular mode set wrong. You probably want it set to radians. Press MODE, move to the third line, highlight RADIAN, press ENTER, then 2ND [QUIT].If it's not the angular mode, please reply to this post and give an example or two.
5/18/2019 9:54:33 PM •
Texas...
Answered
on May 18, 2019
