20 Most Recent Toshiba 36A50 36" TV Questions & Answers
Rca 27v412t tv picture only in middle of sceen
It is the fault with some components related with its horizontal scan output section circuit. Just check the circuit part; and check the components I've marked in red here by its horizontal scan output circuit. Beware; you're going to touch the most dangerous part of its circuit. Keep it in mind always. 24780559-dmive0z32bcpzrsafcaw1enm-4-0.jpg If you wish to see the circuit diagram in full; visit http://schematicscom.blogspot.com/
8/18/2016 3:31:26 PM • Toshiba 36A50... • Answered on Aug 18, 2016
0answers
0answers
0answers
manual
Codes to samsung tv
038,017,082,053,091 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
4/8/2013 4:12:26 PM • Toshiba 36A50... • Answered on Apr 08, 2013
2answers
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
8/4/2012 11:56:37 PM • Toshiba 36A50... • Answered on Aug 04, 2012
1 vertical line across the screen maybe 1" tall.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
7/22/2012 1:57:53 AM • Toshiba 36A50... • Answered on Jul 22, 2012
0answers
3answers
I have a Toshiba 36A50
hi,
Hi check is there is any dry soldering in the vertical scanning stage or in the power supply stage. of your tv. If the soldering of the vertical ic is dry( improper spldering contact coused by years of use) then this can happen.Thats why it disappears some time when there is a proper contact comes. You can confirm is it dry soldering by shaking the tv while its working. If the line comes and go off then there is dry soldering in the vertical scanning section. To rectify this you have to oppen your tv And have to resolder the points in the vertical section. Have added the picture, how a dry soldering point looks.
ok
8/22/2011 9:19:58 PM • Toshiba 36A50... • Answered on Aug 22, 2011
Lost remote. Must do manually on t.v. Two
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
8/17/2011 5:35:40 AM • Toshiba 36A50... • Answered on Aug 17, 2011
Toshiba 36A50 36" TV Logo
104 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 36a50 picture thin white line
  • Televison & Video
