20 Most Recent Canon imageRUNNER 3300 All-In-One Laser Printer Questions & Answers
Canon imageRUNNER 3300. The Display power light is stable blinking but display not on working?
Question edited for clarity, full make and model name. Question moved from Power Computers to model category. Help in the link, but this is an office quality professional unit and should be serviced by factory trained personnel. https://www.google.com/search?q=canon+ir+3300+display+not+working ..
1/3/2024 7:42:25 PM • Canon... • Answered on Jan 03, 2024
Canon ir3300 printing black dots on bottom of paper
Before replacing ir3300 touch screen warm the display with hair drier. It is likely to function normally
10/25/2023 4:53:58 PM • Canon... • Answered on Oct 25, 2023
4answers
In ir 3300 print quality is good but xerox quality is poor
Canon is always bettee than xerox in print/ copy quality
8/19/2022 11:45:52 AM • Canon... • Answered on Aug 19, 2022
5answers
E000000-0000
ir 3300 my error 0000000
8/18/2022 11:48:31 AM • Canon... • Answered on Aug 18, 2022
2answers
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely?
NO: Connect the connectors securely.
2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller
PCB (J300)?
(J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3,
J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3)
12/6/2021 6:38:50 PM • Canon... • Answered on Dec 06, 2021
6answers
I HAVE A CANON IR
my xerox problem E000064-0000
9/20/2021 1:55:00 PM • Canon... • Answered on Sep 20, 2021
10answers
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
11/10/2020 11:42:42 AM • Canon... • Answered on Nov 10, 2020
5answers
I have canon imagerunner 3300 it shows error E000100-0002
E000100-0002
10/1/2020 4:44:17 AM • Canon... • Answered on Oct 01, 2020
2answers
How to solve problem for canon ir3300 in ccd
THis may help:
9/1/2020 2:31:29 PM • Canon... • Answered on Sep 01, 2020
Canon ir3300 - print but double image and missing
HI,
how many copies do you have, when the last time did you change the drum unit or fixing film?
Try first to check the fixing film if you have double smudged and non fixated copies.
2/4/2020 5:48:12 AM • Canon... • Answered on Feb 04, 2020
2answers
I have canon it 3300, all prints and copies out with some black dots on tope of the paper. How to solve this problem. Laser unit is not good and can headed the sound like a siron
Repeating dots are usually the result of foreign material on the drum charge roller or toner adhesion (like a little smashed melted blob) on the developer cylinder. You can clean the charge roller with water. To clean the dev cylinder, wipe the toner off the area, then use strong alcohol to clean any area with the little "blob" buildup. Rotate cylinder and repeat for any remaining. You can usually see the area before you wipe it by looking for a darker spot on the dev cylinder than the rest of the coverage area. Copies will look bad at first after cleaning either. Just run about 20 or so copies. If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
1/3/2020 1:53:42 PM • Canon... • Answered on Jan 03, 2020
5answers
E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
11/12/2019 6:21:49 AM • Canon... • Answered on Nov 12, 2019
2answers
Canon MF4770n error light is flashing and there is
IF the LED screen shows "TONER IS NEARLY OUT", the "ERROR" light will constantly blink and the "ENERGY SAVER" Feature is disabled YET printer copy-fax-scan operation working properly, the solution will be to replace the toner cartridge. This will solve these issues.
9/17/2019 7:37:39 AM • Canon... • Answered on Sep 17, 2019
E000003-0004
. enter SAV- Copier-function-clear-error
7/26/2019 10:26:48 AM • Canon... • Answered on Jul 26, 2019
8answers
Solution to code error E000007-0000
error e000007-0000
5/29/2019 9:58:43 AM • Canon... • Answered on May 29, 2019
When i am going for scan my machine display this
Image Runner 3300 or (iR3300) copiers do not come with print/scan OPTIONS installed. These functions must be enabled by installing the correct 'kit'....same with fax option...again, these were 'options' when this machine was introduced, no print, scan, fax,...unless options were added to it. Yes, the buttons are there, however.....
12/13/2018 9:25:21 AM • Canon... • Answered on Dec 13, 2018
ERROR IS E-000225-0002
top glass error or ccd,or mirror adjustment
12/4/2018 12:15:39 PM • Canon... • Answered on Dec 04, 2018
2answers
Canon ir 3300 ,this has
canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???NO KEY IS FUNCTIONING NOW.................mail at [email protected]
11/13/2018 9:28:55 AM • Canon... • Answered on Nov 13, 2018
How do I correct an error code e000021-0220?
error e000021-0220
11/4/2018 7:55:56 AM • Canon... • Answered on Nov 04, 2018
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,164 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error code e000007 0000 in caonon ir
  • Office Equipment & Supplies
