20 Most Recent Hunter Fan Company 5/1/1 Programmable Thermostat Questions & Answers
3answers
Low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
7/29/2021 4:23:45 AM • Hunter Fan... • Answered on Jul 29, 2021
Regardless what I do I
I have a solution!!!! Ok, hit the filter key. You will see the filter counter screen. Hit and hold the RET/CLEAR key until the Filter flashes and it clears the counter. I just found it by trial and error. I wrote it inside the cover so I could remember.
9/22/2020 3:20:34 PM • Hunter Fan... • Answered on Sep 22, 2020
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh? Is this a 'new' problem? Has it worked properly before? Then there is this from the manual: The installer can set SYSTEM functions once the thermostat is installed. The default settings are shown in bold in the following list. Options are listed inside the parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings. Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'... It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is: Download manual TROUBLESHOOTING begins at Page 68 Anthony
12/24/2017 4:33:39 AM • Hunter Fan... • Answered on Dec 24, 2017
I have an old Bryant
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
6/9/2017 9:15:18 PM • Hunter Fan... • Answered on Jun 09, 2017
0answers
2answers
Builders installed my underfloor heating with the
hi,
Ive been looking for about 20 minutes now and unable to find a direct link to the owners guide, I did locate the phone number for wickes support for you..
Please contact our Customer Services on 0870 608 9001 and we will be able to assist you.
jm
4/8/2016 6:36:22 AM • Hunter Fan... • Answered on Apr 08, 2016
I need a Manuel for this model44155C
try: (888) 880-FANS their office will probably send it to you.
2/5/2016 10:57:35 AM • Hunter Fan... • Answered on Feb 05, 2016
2answers
Hunter 44360 thermostat wiring
If you don't have the wiring information, go here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf and see page 10.
If you're still having problems, go down to the furnace room and find the piece of equipment that you're wiring to.  See where the wires came from, transpose that to the information above.  Note: the wiring from the relay box should be 24 volts which is safe to handle.  Wiring inside the relay box may be 110 or more volts which is not!!!  Cut power before opening relay boxes.
As far as heater running continuously, be sure of your wiring.  You may have the gas relay lead and the fan lead reversed.  Determine if you've set the switch options for your type of heater correctly!!!  Do you hear the relay clicking in and out at or near the room temp when you change the setpoint?  If not, the unit may be defective.
11/27/2015 6:17:15 AM • Hunter Fan... • Answered on Nov 27, 2015
2answers
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
3/13/2015 10:21:31 PM • Hunter Fan... • Answered on Mar 13, 2015
My furnace will run properly for 2-3 hours then at
usually this is a bad thermostat, no signal to furnace. have a great day!! if not the furnace its the thermostat not turning furnace blower on.
3/4/2015 12:51:48 AM • Hunter Fan... • Answered on Mar 04, 2015
How toBypass programmed thermostat settings on Hunter
Here's the online Manual Search page at Hunter Fans & Thermostats: http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals See Page 8 of Manual Override programming for this thermostat: http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf GL
3/3/2015 5:17:46 PM • Hunter Fan... • Answered on Mar 03, 2015
2answers
Heater does not turn off
It could be, or it could be a wiring issue. Make sure that your wires are in the correct place (R or Rh and W), and that they are not touching each other. If you have the unit running, and you disconnect either of the wires, it should shut off. If it does not, then the problem is in the wiring. Hope this helps
1/31/2015 11:55:47 PM • Hunter Fan... • Answered on Jan 31, 2015
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine; Note the sensor channel on face of remote (ref: http://www.manualslib.com/manual/257219/Hunter-44665.html) Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7. Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp. Note the button order for Remote Sensor Programming at base thermostat: http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
12/30/2014 11:47:23 PM • Hunter Fan... • Answered on Dec 30, 2014
2answers
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
12/30/2014 11:46:55 PM • Hunter Fan... • Answered on Dec 30, 2014
2answers
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
12/8/2014 6:17:03 PM • Hunter Fan... • Answered on Dec 08, 2014
Could you show a picture of exactly where these small wires should be placed? Same problem as Dina!!
Go to the website of the thermostat. You can download the owners and installation manuals there.
10/10/2014 9:03:34 PM • Hunter Fan... • Answered on Oct 10, 2014
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
344 questions posted
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hunter Dryers
  • Hunter Dryers
Most Popular Question
thermostat will not stay setting set
  • Dryers
