With working sim in phone, go to keypad and enter *2767*3855# and wait, this will fully reset phone so ensure you back up anything on it first, during repowering up remove battery and insert sim from other network then turn back on, phone should now be sim lock free. As always this is at your own risk.This will likely work with other Samsung phones
You can use PUK code from your sim card to unlock samsung tocco F480 password.Just type any password until your screen asking PUK code, then enter you puk code to your phone. This method should be unlock samsung phone from old password.
For some reason some of the newer Samsung phones require you to set up the MMS services and also the Internet on their phones. If you visit www.samsung.com and follow support and FAQ's it will show you how to do this. Good luck!
There are many methods for unlocking mobile phones, but codes are best one, because it is easy and safe also, you can get the unlock code for your Samsung model mobile, through this site http://www.theunlockarena.com/samsung-sgh-f480/rs13wp9/ It has the best instructions and easy methods for unlocking mobile phones..........
Hi, You can unlock your Samsung F480 locked to t-Mobile safer and easier using unlock code. you can get the unlock code for your Samsung F480 from www.Unlocking4u.com at affordable cost with free unlocking instructions. All the best mate.
i just downloaded bible to my samsung f480 need to use wap. go tis website with samsung f480: www.biblephone.net/jar u can choose different language bible from there.
hi
try these codes
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
Here is a link for the guide on taking apart the Samsung F480 Tocco. This will show you how to replace the lcd screen and provides links to purchase a new screen as well.
Can you recover deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and restore deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
