Ir 3300 my error 0000000
E0000000-0000
Change heater elament or clean the fuser unit
SOURCE: I am getting the error
I am getting the error E00007-0000 on the display of my Canon iR3300 printer.please advise how to solve the problem
SOURCE: Error Code E603-0002
its a hard disk problem.
format the hard disk & install soft ware
its not ok finally replace the hard disk with new
SOURCE: Canon IR3300 model has some problem.
Don't recommend PCL6 for this copier. Try latest PCL5e and PS.
If that doesn't work get tech to come out and load latest firmware and see if it works.
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
Ir 3300 error cord E000000-0000 catcha na
