ADF too much paper taking in one time. when I copying paper missing. pleas give me advice.
Adf have limit lines, can only hold so much paper, also is your paper folded,stapled,or humid, could be syicking together. Fan paper good, u can test it with new unused paper as a yes, count originals then copy, also separation roller or pad could be worn, if rollers are bald like car tires, then they will need to be replaced, also, take clean rag with water, wipe rollers and pad, you adf will run luke new for 1 set, if this is the case, then you proved your rollers are worn.
Change the adf main rubber
Check the paper thickness. It can be a problem. try with another paper.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
