SOURCE: the screen is just blue... apparently, the red ad
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.They have put together a kits for most models. If you don't see a kitfor your set send them a quick note and they will put one together foryou. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
SOURCE: Continuous alternating one green and three flashing red battery
NOTE: Battery
operating time (the time the battery can hold a charge) decreases over
time. Depending on how often the battery is used and the conditions
under which it is used, you may need to purchase a new battery during
the life of your computer.
Check the battery status light —
If the battery status light flashes orange or is a steady orange the
battery charge is low or depleted. Connect the computer to an
electrical outlet.
If the battery status light flashes green and orange, the battery is
too hot to charge. Shut down the computer, disconnect the computer from
the electrical outlet, and then let the battery and computer cool to
room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Testimonial: "Spot on. Thanks"
