Televison & Video Logo
Malomo James Posted on Nov 13, 2019
My Olevia 527S11 LCD tv is not showing pictures and sound i noticeed one of the capacitor is bad ,how can i replace or trouble shoot.
Walt Schuman
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 16 Answers
  • Posted on Nov 14, 2019
Walt Schuman
Contributor
Level 1:
Welcome Back:
Answers
16
Questions
5
Helped
2324
Points
55
If the cap is domed, the top is bursting upward, read the value on the side, might be something like 1000uF, 50V ,buy a part online, try to get one rated at 105 C, then you have to remove the board and solder the new part in. or write down the part number of the board, and model number, to buy the entire board online
5 Related Answers
Anonymous
  • Posted on Sep 05, 2009
SOURCE: screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Anonymous
  • Posted on Oct 18, 2009
SOURCE: Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
freetek
Steve Allison
  • 5569 Answers
  • Posted on Nov 22, 2009
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
freetek
Steve Allison
  • 5569 Answers
  • Posted on Dec 02, 2009
SOURCE: olevia lcd tv has sound but no picture... Used
Try viewing the screen from a flat angle with some light source at the opposite angle while turned on. If you can see image 'ghosts,' then either the backlight fluorescent or the high voltage inverter for it has failed. This may not be cheap to repair but I wouldn't consider it a death notice.
If you or a tech finds which it is, you might try here for the board:
Jimmy's parts
These will be 'pulls' from mfr. overstock or disassembled sets. They do offer a warranty.
If the backlight has failed, I'm pretty sure a tech will know where to get them.
Anonymous
  • 10 Answers
  • Posted on Apr 23, 2010
SOURCE: I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
Yeah I got the Olevia 537 and I was trying to set it up without a remote and I got that first screen where it's at just chill room and power up and I can't get out of it I turn it off on unplug during...
Nope, all sets NEED a remote control. Only basic functions from the set. Just buy a new remote SPECIFICALLY for that set
Olevia TV, Video & Home Audio Remote Controls for sale ' eBay
www.ebay.ca > Olevia-TV-Video-Home-Audio-Remote...
Results 1 - 35 of 35 - GENUINE OLEVIA ?LEVIA RC-LTU UNIVERSAL REMOTE 537-B11 537-B12 537H 542-B11. C $43.40. Free shipping. or Best Offer ...
Customer reviews: Universal Remote Control Fit ... - Amazon.com
www.amazon.com > product-reviews
Find helpful customer reviews and review ratings for Universal Remote Control Fit for Olevia RC-LTU 2500005701 537-B11 537-B12 537H 542-B11 542I 742I ...
olevia tv remote control - Amazon.com
www.amazon.com > olevia-tv-remote-control > k=olevi...
Results 1 - 16 of 118 - New RC-LTL Replacement Remote Control fit for Olevia 5 Series LCD HDTV 526 527 532 537 542 527S11 527-S11 527-S12 527V 532B1 ...
Model ELDFC551J 55" element tv , turns on and picture can be seen very dim when light is shined on the screen. Tv has sound. Set was working great the day before. How can I trouble shoot.
LCD TV backlight lamp is usually the culprit... On my TV, however, it's the capacitors that gave out. You can tell the capacitors are bad when the top part of it is not flat and it's bulging.
2answers
The screen is blue but nothing shows for tv or dvr
Hi Mike,
If your TV is more than 4 years old cost of repairs will probably be more than a new or refurbished replacement.
Here's something to try:
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
No picture no sound.any ideas?if I shine light to front I can c olevia.and sometimes if I turn of and on it will light then go blank.
- Flickering screen
- Dim screen
- Slow start
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
1helpful
Sound but no picture with vertical lines
its sounds that you have a bad t-con board, but before you come up in trouble shooting with in the t-con board. you must check first the power supply board if has bulging electrolytic capacitors and common is leak.
The power indicator light is on but no picture and no sound!
bad power supply due burned or bulgy capacitors do this undo the back and check for any bad capacitor.
replace with the proper one.
rate me please
5helpful
4answers
My pwoer supply blew up as well part number HGP 180-p240JIFE
Ladies and Gentlemen,
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
Fastest Robe
10helpful
5answers
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Olevia LT23 23in. LCD/TV
I had the same prob, but found out that the problem with the Olevia lcd tv's on most models not powering up is because of failure of capacitors on the power supply board that I do believe is due to excessive heat and lack of ventilation.
I took the tv apart and got access to the main board and just by looking at the capacitors I could tell which one were the bad ones..
I will show some pics that I borrowed during my repair, hope it helps as reference as it did to me.
I replaced the bad caps with new ones that I bought at a computer parts store.
Now I got my lcd tv back ON but this time I added a internal cooling fan for better air flow that will reduce this malfunction from happening again.
Hope this helps.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
