Timex 1440 Nylon watch Logo
Anonymous Posted on Feb 15, 2008
Timex 1440 sports watch, WR50M
I have searched high and low for instructions on how to change the time on my Timex 1440. It only has three buttons. One is mode, one is start/stop and the other is lap/rst. can you help as all the other watches seem to have four buttons.
J HINCH
  • 11 more comments
  • Anonymous Feb 29, 2008
    it won't change the time it says it can only be either 5:44 or 5:14 and on my time its 8:18
  • jaba2005 Mar 05, 2008
    Mine has buttons, but one is just an indiglo button. I can set the time on mine, but I can't get it off of military time.
  • Anonymous Mar 09, 2008
    can not reset time
  • lucycat0 Mar 13, 2008
    i've set the time on this thing once and remember it being a convoluded process... somehow two buttons being pushed simultaneously was involved but i can't find the right combo. To help others out.. here what some of the combos do change:
    - hold ADJUST button (alarm time is shown) while holding the button push the START/STOP button to cycle through hourly chime, (little clock), alarm (bell), both, or neither.
    - hold ADJUST button again and while holding hit MODE to cycle through military time and regular time.
    - hold START STOP button and while still holding hit ADJUST to cycle through european date vs us date.
    unfortunately as you can see, i've run out of two button combo's and still no time reset feature... hmmmm.
  • Anonymous Apr 06, 2008
    I'm having the same problem. I just bought the watch and I have the instructions but I still can't figure it out. Help!
  • Anonymous May 10, 2008
    wre50M has three switches....can not change to current time...
  • Anonymous Jul 22, 2008
    I just bought the Timex 1440 Sports Watch, and to turn off the alarm and chime, I held down the "set" button (bottom right) and pressed the start/stop button. Repeat.
  • maxlol Nov 28, 2008
    ya i know its so annoying
  • kuzzy_1 Dec 28, 2008
    how take the pulse? please
  • Anonymous Mar 13, 2009
    I have exactly the same problem. Why so user unfriendly???
  • Anonymous Oct 15, 2011
    With my watch u press the top left corner button until the sec. start to blink. Then with the bottom left button you can change to the time or the date. Last of all, you press the top right button to change the date or time;ect.
  • Anonymous Mar 12, 2013
    As I was searching how to change the time for DST, I somehow got the elapsed time switched to only seconds (instead of seconds to minutes, which I prefer). Any idea how this happened and how I can change it back? Mine is the Timex 1440 wr50m. Thanks!
  • Anonymous Mar 16, 2014
    WIND
Anonymous
Level 2:
President:
  • Expert 1 Answer
  • Posted on May 12, 2008
Anonymous
Expert
Level 2:
President:
Answers
Questions
0
Helped
113856
Points
485
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Anonymous
Level 2:
  • Expert 1 Answer
  • Posted on Apr 16, 2008
Anonymous
Expert
Level 2:
Answers
Questions
0
Helped
113856
Points
326
Setting My Timex 1440 Sports Watch (4-button)
This model (WR50M) has four buttons, from left to right, top to bottom: 1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds)
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Mar 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
118393
Points
57
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Anonymous
Level 2:
  • Expert 2 Answers
Anonymous
Expert
Level 2:
Answers
Questions
0
Helped
121045
Points
114
Ok - i messed with this forever. i have some solutions, but not all.
* To get it off military time, do this:
while in time mode, hold down the "adjust" button (bottom right) and then press the "mode" button (top left). you'll notice that the "P" below the alarm time disappears and appears, just as the hours switch from military to non-military mode. (best to do this in the afternoon)
* You may find that the date gets weird looking after you mess with the buttons long enough. chances are it switched to European date mode, which places the day before the month (freaks). To switch back, hold down "start/stop" (top right) and then press "adjust" (bottom right).
Now if anyone can tell me how to set the date, I'll be psyched.
  • Anonymous Nov 07, 2012
    OH MY GOSH thank you SO MUCH! I have, for the longest time, had it in eurpean date mode. Never got around to changing it. So annoying. Now I have. You made my day.
Anonymous
Level 2:
  • Expert 3 Answers
  • Posted on Aug 01, 2009
Anonymous
Expert
Level 2:
Answers
Questions
0
Helped
167216
Points
101
Setting the Timex 1440 Sports WR50M T5G891:
  • This model (WR50M) has four buttons, from left to right, top to bottom: 1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
  • To set or change the time:
  • Press and hold Set and Start/Stop simultaneously; the seconds will start to blink
  • Release both buttons
  • Use Mode button to toggle through to Hours, Minutes, etc.
  • When desired number (such as Hours/Minutes) starts to blink, use Start/Stop button to change number
  • When done, hit Set
  • sophia985 Oct 23, 2010
    i was to confused and my watch didn't do that so ya
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
113856
Points
6
Solution 5 worked for me ...after messing with my son's watch over an hour! frustrating for sure!! The buttons on our watch are (from top left and clockwise)..Set ; St/Stop ; Indiglo ; Mode (being bottom left)
  • Anonymous Mar 20, 2009
    I meant to say solution #4 worked for me on my son's watch...sorry
Anonymous
Level 1:
  • Posted on Nov 03, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
113856
Points
5
Anonymous
Level 1:
New Friend:
  • Posted on Mar 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
113856
Points
Solution 5 worked for me as well!
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
137057
Points
11
Uh, yeah, its like, so easy! i have a purple sports timex 1440, and it has: mode, start/stop, set, and indiglo. it just broke at the kroc center. :(
i hope you find it easy. you just have to hold mode down until it blinks. press it again to go to the time. (the first time is the alarm) push start/stop to toggle, push start/stop again and again to go to the date, day, and then return to time. but if you do the alarm, you have to hold mode down again. i hope you can figure it out now.
i wish i could get my watch to work again. too bad it rusted. :(
remember, today is a time machine, what you do today will effect your future!
bye for now!
on wizard101, i am julia watersword. bye!
good luck,
tornado
  • Emilee Churchill
    Emilee Churchill Nov 29, 2014
    what does the indiglo button do
Anonymous
Level 1:
New Friend:
  • Posted on Jun 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
113856
Points
To set the time, all you need to do is press "set" as well as "start/stop" simultaneously. You need to ensure that you have got both buttons on at the same time and don't release it immediately. Once you press both of these buttons down, you need to keep it this way for at least a few seconds. Then, you will notice that the numbers on your watch face will start to flicker. The numbers that blink should be the numbers representing the seconds.
Once you have the numbers flickering, you can start setting or changing your time. You now have to use the "mode" button to change either the date or time on your Timex WR50M. Adjust the timing as to the number that you want to. Once you have done so, just press the "set" button and your timing and date has been adjusted. The process is really simple, isn't it?
A
Anonymous
Solution 5 worked for me with an older 1440 Sport with the button set-up being (clockwise) st./stop, lap/rst. , Mode and indiglio. To convert this watch back from military press mode and lap/rst. simultaneously and curse Timex for not putting older manuals on their web site
    what ever you say
A
Anonymous
Here is the user manual to the watch (or one very similar). Very explicit eacy instructions.
http://www.sports-watches.co.uk/watch_manuals/5e061.pdf
In this particular model:
1) Holding mode key for 2 secs will enter the adjustment mode.
2) Press mode button one more time to get to "time adjustment", annd then use the "start/stop" and "set" keys to adjust the time as usual.
Anonymous
Level 1:
New Friend:
  • Posted on Sep 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
113856
Points
None of the above worked for me, but did give me the clue of push the button and hold it down...On my watch, you Press and Hold the "set" button top left button. then the hours flash, you can press Indigo to change hours then set. Then minutes, indigo, then set.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
113856
Points
Goto http://www.timex.com/info/Product_Instruction_Guides_Downloads
then find the Timex module table directions to find the correct manual
A
Anonymous
This works [email protected]
Coordinated Universal Time (UTC) is the basis for the worldwide system of civil time. It is
determined using highly precise atomic clocks at time laboratories around the world that are
accurate to a billionth of a second per day. UTC time signals are broadcast via low frequency
signals. Your radio controlled Timex® watch synchronizes its time to the broadcast time signal.
PLEASE NOTE: This product only works in North America.
A. In TIME mode, press and hold SPLIT/RESET. Watch will attempt to synchronize time with
nearest time broadcast and tower symbol will flash in display. This may take up to two
minutes.
B. Watch automatically attempts synchronization at 1:00 am daily and 4:00 am Sunday
local time.
C. Tower icon ( ) appears in display if synchronization has been successful within 24 hours.
TIPS:
WARNING: Depending on your location, the watch may be unable to pick up the radio signal
from Colorado. Synchronization may also not be successful if your watch is near a source of
interference (e.g., computer monitor) or you are in a building with a metal roof. Cloudy or rainy
weather conditions may interfere with radio signal transmission. If synchronization is unsuccessful,
try the following:
• Rotate watch 90 degrees.
• Move to a wall or window facing toward Fort Collins, CO.
• Move at least 2 meters away from any computer monitors.
• Move outside. If it works outdoors but not indoors, you may have a local interference
problem in your building.
If your watch is off by one or more hours: make sure you have properly selected your time
zone (see below). If you are in an area that does not observe Daylight Savings Time (DST),
be sure DST is disabled on your watch.
If your watch is off by a few minutes or seconds: make sure that your watch is currently
receiving the signal (tower icon appears in display).
If your watch did not adjust time for DST, make sure that your watch is currently receiving
QUICK START FEATURE: At any time, you can press and hold SPLIT/RESET to force watch to
attempt synchronization.
For further information on synchronization/interference issues, visit the U.S. government
    first of all my watch is a girl watch so it totally different on how to set it
sophia985
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 23, 2010
sophia985
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
114621
Points
13
How do you set a green sports 1440 timex watch girls watch
  • 1 more comment
  • Anonymous Sep 05, 2012
    I have the same one In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
    I have the same one.
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
My Timex 1440 Sport model WR50M makes a beep whenever I press a button. Is there any way to silence that?
no the only way for this open your phone and remoe the speaker in that and it stops sound thanks
3helpful
Instruction manual for timex 1440 sports wr50m watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Sep 28, 2010 • Watches
How do i get the timex 1440 sports watch military time to change the hour and minutes wont change
manual download"
8helpful
How to change the time on a timex 1440 sports watch WR50M
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX .Rate me, please..
How do I change to time and date on my radio controlled timex 1440 sports watch. (it has three buttons on each side)
manual download"
3helpful
I need set up instructions for a wr50m 1440 sports watch
Visit www.timex.com/ - 12k - Cached - Similar pages
Choose: SPORTS, then SPORTS1440 and download manual.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
