20 Most Recent Toshiba TEC B-452 Thermal Label Printer Questions & Answers
How to fix a misfeed in printer on toshiba
I have a toshiba estudio 452 when i want to print it shows E550 but there is no paper in the paper feed area , and I checked it several times
3/30/2016 3:44:22 AM • Toshiba TEC... • Answered on Mar 30, 2016
Can't run TEC Label Software
Download driver from seagullscientific and reinstall GBAR As far as I can remember the windows driver used was from seagull scientific. www.bartenderbarcodesoftware.com
9/11/2014 6:07:55 PM • Toshiba TEC... • Answered on Sep 11, 2014
HOW MANY 50mm LABEL IN 1 METER WAX
1000 / 50 + 2 that is approximately 18
9/10/2014 3:36:01 PM • Toshiba TEC... • Answered on Sep 10, 2014
Tec 452 printkop
Check the fonts used. Probably a driver problem
9/10/2014 3:29:00 PM • Toshiba TEC... • Answered on Sep 10, 2014
Tec b-452 barcode not clear
change the heat value and the speed value or you may have the wrong ribbon
9/10/2014 3:26:08 PM • Toshiba TEC... • Answered on Sep 10, 2014
How do i clean the printhead on toshiba B452?
Try alcohol and a soft cloth or cotton. But I'm afraid you'll have to change the print head.
6/10/2014 7:08:55 AM • Toshiba TEC... • Answered on Jun 10, 2014
How to fix an error?
First of all check that the ribbon core is correctly placed with the notches fitting on the Green wheels. If th ribbon coe is not secured the wheel will not turn and no ribbon will be detected. If your core is too short and with no notches, you'll have to glue a pice from another core an create a notch.
6/10/2014 7:05:53 AM • Toshiba TEC... • Answered on Jun 10, 2014
HOW TO PRINT IMAGE BARCODE USING JSP APPLICATION
what is jsp
1/14/2014 8:14:56 AM • Toshiba TEC... • Answered on Jan 14, 2014
Thw sensor isn't working
Check that it is correctly selected or change the sensors
1/14/2014 8:11:59 AM • Toshiba TEC... • Answered on Jan 14, 2014
New preprinted labels with black
Either you recllibrate the sensors or no other solution exists
1/14/2014 8:05:15 AM • Toshiba TEC... • Answered on Jan 14, 2014
How to program a txt file for 2 labels in a
Use bartender ultra light available with each printer will do the trick
1/14/2014 7:50:52 AM • Toshiba TEC... • Answered on Jan 14, 2014
I cant able to install
Get the drver from your toshiba dealer with a more recent bartender 10.1
1/14/2014 7:45:51 AM • Toshiba TEC... • Answered on Jan 14, 2014
When i press the feed
Send the correct length to the printer. Use a windows driver to sent a test page at the correct size and dectection
1/14/2014 7:42:33 AM • Toshiba TEC... • Answered on Jan 14, 2014
I install printer on xpopereting system machine
Check the detection and the label size. Use no detection if it's continuous media or transmissive or black mark but if you use detection sensor check that the size is correct.
1/14/2014 7:41:05 AM • Toshiba TEC... • Answered on Jan 14, 2014
My tec b452 printer is
Check that you are not in direct thermal mode and if the roll is correctly placed on the supports. If the roll is not meant for this printer then you have this error
12/9/2013 2:09:38 PM • Toshiba TEC... • Answered on Dec 09, 2013
Print spacing is erratic
You have to callibrate the sensors and check your settings in the driver
12/9/2013 2:06:20 PM • Toshiba TEC... • Answered on Dec 09, 2013
Change the testine
I have the manuals
12/9/2013 1:53:03 PM • Toshiba TEC... • Answered on Dec 09, 2013
I have a TEC B-452 which ran fine on my older
check that you have chosen the correct detection (Trasmissive) This looks like you are using continuous paper.
12/9/2013 1:30:18 PM • Toshiba TEC... • Answered on Dec 09, 2013
ONE LABEL (ON OUTER EDGE)
probably dots broken on the print head
12/9/2013 1:21:44 PM • Toshiba TEC... • Answered on Dec 09, 2013
How do you do a printer report on the 452 toshiba
Swtch on with pause key depressed and wait for the power and online leds blinks and error led off. To cahnge from thertransfer or direct printing mode depress feed and pause spontaneoulsy. By depresing feed the self test is printed
12/9/2013 1:13:39 PM • Toshiba TEC... • Answered on Dec 09, 2013
Toshiba TEC B-452 Thermal Label Printer Logo
33 questions posted
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba TEC Office Equipment & Supplies
Most Popular Question
many 50mm label in 1 meter wax
  • Office Equipment & Supplies
